Hello, I'm still here and keen to get KR working.
Please note, when you're putting PIDs into the equation editor you *want* to prefix them with '22'
So, KR (11a6) is:
2211a6
in the PID box at the top of the extended PID editor. This should help.
Also, I'm not *entirely* sure 11a6 is the correct PID for KR, though if you change the PID in the extended editor, delete (if already on the screen) and re-add the display for the PID on the 'realtime information' screen, connect with the engine at idle for a few moments (so it can pull some data) then use the 'Send comms debug log' menu option, I'll have a look.
Please make sure you put something in the description field (like GP KR, etc or an email if you want me to get back to you) otherwise I won't know what it's about
Thanks
Ian
Hi
If that's the case then it should be a simple issue of making sure that it's 2211A6 in the PID editor in Torque.
If that is the correct PID, and it's not working, then it might require, in the vehicle profile, the "Use alternate OBD2 header" tickbox to be set (make sure you quit and restart torque after doing this to make sure you start a new connection)
The alternate header may cause all the normal dials to stop working, but the KR may *start* to work - and not knowing if KR needs the engine running or not to produce values other than 0)
Either way, if you're using 2211A6 and have the display on screen for a few seconds, a 'comms debug' (accessible from the menu on the realtime info screen) would be very helpful! (just make sure you put what it's about in the description)
Regards,
Ian
