minichopper6hp
Banned - Busted For Scamming
i might just build one so everyone can see
Logan
Logan
I think it's cool, but what would be the benefits from A2A over W2A? would it be cheaper or more efficient?
I know that this was built in Australia, but I was wondering if the GPF member had produced his own.
For me, the single loop system offers advantages, or peace of mind if you will, because if the W2A unit leaks it will kill your engine. Throw a big enough FMIC on the car and the intake charge will be at near ambient temps.
Lag would be a disadvantage as everybody has mentioned, but it shouldn't be nearly as bad as a turbo.
If your worryed about a leak or a failed intercooler pump why not look into a aeroforce scan gauge? That'd be a hell fire way to keep tab's on knock. If you see a large jump in knock at wot. (IMO any knock) then it's pretty much a no doubt issue that somthing is going on with that car that shouldnt be. Let it be a failed i\c system or some one put cheap gas in the car.
^ by the time it takes to realize whats going on the engine is done anyways
If the manifold mounted heat exchanger bursts/breaks/etc and pisses its fluid into the intake, how would the gauge help?
