I like that belt setup but I would be concerned with the belts interfering with the IC hoses the way I have them routed. That build is truly inspiring though, I need to sit down and read the whole thing when I get a minute.
An upgraded blower would be a sick build for the future. I'll never be done modifying this car and will probably re-do and upgrade things that I've already re-done and upgraded.
The HUD took like 80 hours to do. I'll dig up some pics of the progress when I'm not so busy, but the description would be as follows:
Mold GP HUD bezel and Impala defrost grille together and try to get it to look like one piece. Trim the GP HUD bezel to fit the Impala dash pad. I was unable to use the factory clips of the GP bezel so I cut them off and epoxied a bolt sticking down through a hole I drilled in the dash with a nut on the other side to keep the bezel seated in place. Cut a hole in the Impala dash pad to fit the HUD unit. Cut the HUD unit itself in half and plastic weld it back together thinner so it will fit in the Impala dash. Cut the heater tube that passes under the dash pad and seal it off. Make some sort of brackets to hold the HUD in place with it aligned correctly so you can see it in the windshield with the bezel in place. The wiring is relatively straight forward but you cannot tap into the cluster wires. Turn signals at four way switch, high beams at multifunction switch, VSS wire at BCM. I mounted a GP HUD switch in the cubby where the ash tray was. Lots of fine dremel work. Probably 80 hours of combined effort of me and two other friends. Worth every minute in my opinion but would not want to do it again.
Wiring harness is mostly done. Needs loom, a few things need to be extended, etc.. But I really like how it is routed and it is barely visible.
Replaced all of the subframe mounts with new firm ride ones from GM.
Finished painting a bunch of odds and ends.
..And the long awaited mating of the subframe to the car.
Finished the brakes and got it sitting on all four tires again. Note to self: BLEED THE BRAKES BEFORE DRIVING
Mounted the heat exchanger and pump. Almost finished plumbing everything in. Had to plug the holes that were in the IC reservoir and tig in some new bungs on the side of it. Trashed the 5/8 fittings and threaded it for 3/4 so it won't hinder flow. May have to move some of the lines around but won't know until I get the bumper on.
I think its looking pretty good so far. Can't wait to take this same picture when its finished.
Started fabbing some new diagonal braces. They're going to be equal length. When nobody makes it the way you want it, you make your own.
Coil packs mounted to the strut tower brace, up and out of the way. Lengthening the ICM harness is going to be fun.....
None of us thought the hood was going to close so it was a pretty big moment when it latched without a thud. Even with the engine rocked forward it has about 1/2" clearance from what we can tell. I did flip the throttle body adapter upside down, pretty sure it would have hit.
All this plumbing and wiring is the most time consuming part of this project.
