Scottydoggs
Killa Bee
its a bit older and CGI was not what it is today, messed up movie tho.
Not as bad as this
Back on topic, here's a picture of where I lift my GP from. Mine's an 02, so the pinch welds aren't too bad for Michigan. I still go for the frame though. And the place in the rear of the car I believe you were talking about was the trailing arm mount, which I believe is okay, but the back of the car isn't nearly as heavy as the front, and my rear pinch welds look better than the front so I do go for the rear pinch welds.
It's a video still frame from my oil change. You can see the pad is on the uni-body frame.
You will not damage your sub frame by lifting it there, I've never seen a car rusted through the frame that bad. If you're talking about the rear pinch welds, I wouldn't worry about them. Even if the pinch is gone, the metal under it is what's really supporting the weight.It can damage it if I lift from there. Btw. Ur car is still good with rust.
I had like pieces falling omg.
Anyway the guy from the alignment said the brake and fuel line about to crumble. And the ill have no brakes.
Wth?!?
por ( paint over rust) paint would be better to use, but changing them would be best. last thing you want is to NEED YOUR BRAKES and not have any, they always seem to blow out when you nail the brakes real hard.
for the front you can set the jack right where the bolt for the rear sub frame bolts in, i use that all the time for the fronts. you can also put a jack stand under the front sub frame along the sides. where the lower control arms mount.
the rears by the frame mount also. billBoost37 posted some pis of his rear suspension replacement how to, shows where he put the jack stands in the rear.
You said it's not so bad. Look now. I didn't even start yet.![]()
What so u think now?
