Shiftingshaddow
ZZPerformance - Modular Pulley System #ZZ-38MPS
My SC appears to be leaking. there is an oily residue on the sc and kind of going over the intake. i'm just figuring that is what the residue is. Its kind of a dirty ring around the pulley, too.
One of my question is do kits like these come with a seal or gasket? i can't tell what the little black thing is on the bottom right in the picture. there wasn't a gasket or seal available by itself that I saw on the website.
since its gotta be pulled and fixed i figured i might as well put one of these on there just in case somewhere down the line i wanted to change sizes. i was going to get a 3.5 with this kit. its a 2001 gtp special edition. got it for 2100. 175k with a newly "overhauled" transmission. my third gtp.
stuff i have to do to the car.....valve gaskets and cat converter leaks and resonator has holes in it. needs at least one axle, outer tie rods, hubs. i have an extra stock converter and am going to just have a pipe put in where the resonator is. probably put plugs and wires on it. it doesn't appear to be leaking coolant anywhere but its pretty greasy so i need to clean it up a bit to tell if it needs intake done.
i'm kind of thinking about putting headers on it. hoping i don't have to go underneath to do the rear headers and maybe with all the stuff off doing valve covers they can fit in the top side? i read the headers write up and was hoping not to have to do it that way. any suggestion on which ones to get? the ones i was looking at were like 100 bucks or something. i haven't looked into this a lot, really. so what do you guys use? i'm not planning on building this thing up a lot, btw. headers with a stock cat work? any other things need to go with it?
just seen a lot of mixed things about what is needed for pulley drops, how effective which headers are, having the ubend delete done or having a high flow cat on it. so, idk if its worth doing for 3.5 or if it just tossing money. if nothing else, different headers will look better than those rusty stock ones with the alien tin foil on them. they're probably a pain to get off......:th_shakinghead2:
