are wheel spacer good or bad?
03limitedgtp
I have a 2003 limited gtp and I don't wanna take of the limited edition wheels but looking for a wider stance would it be bad to get 1 1/2 or 2in spacers?
Don't think I've ever seen anyone with a go do that big of a spacer?
Sent from my DROID RAZR using Tapatalk 2
- Hub-centric spacers is preferred over the generic spacers as they are more stable thus less vibration issues.
- Use of spacers can lead to "premature" wheel bearing wear, but the term premature is relative. So you will have to decide if the risk is greater than the benefit. Although with the ****ty hubs we have on w-bodies, Id stay away.
- Use of spacers can lead to "premature" suspension wear also, if the offset is large enough. If the difference is that great, you may want to consider having an alignment done on the car.
- Wheels falling off is another possibility with spacers, but it is most likely to happen because of user did not get the correct bolts or installation error. However, since it is an add-on parts, the possibility of spacers cracking also exists. It is rare, especially with quality spacers, but it is not impossible.
IMO, wheels with build in desired offset > hub-centric spacers > ebay spacers. That said, having run the wheels you have, Id just get rid of them and get something nicer. Proper quality spacers will cost you some big bucks. (~400 bucks per 4 proper hubcentric spacers bigger than 15mm)
It's really not worth worrying about it every time you drive, is my wheel gunna come flyin off at 60mph, did that last pot hole finally do it? Is this gunna kill my wheel bearings? Is this murdering my tires from the suspension being out of whack?
Just go to tire rack and get some nice wheels with a better offset. Mustang wheels work nice.
LOL b/c wrong bolt patterns are better than spacers. Idk would you rather risk breaking wheel studs? Argument goes both ways. I have 8mm spacers with no problems but that's considerably smaller than you are wanting
Em incorrect there broham. Plenty of guys run the mustang 5x114.3 and have yet to break a wheel stud. Hell most of us run 5x114.3 because there's a bigger selection of wheels. For the past 4 years I've ran 114.3 with 0 broken studs. The different between 115 and 114.3 is very minor. You could always run centric hubs if you feel the need.
A minor spacer is fine but I would go any bigger then 10mm. Personally arp wheel studs are cheap enough to change out to if there's any concern.
People are not going to break wheel studs because of running a 5x114.3 vs a 5x115. Chances are, those who are breaking wheel studs, would have broken them running a 5x115 wheel anyway.
I'm not saying he would have a problem, but it's about as common as having problems with small spacers, as we both mentioned, wouldn't be a problem.
I don't think you should waste on spacers with stock wheels
0.7mm (1/36th of an inch) is within manufacturing error. considering mustang wheels fit and have practically the same (70.5 vs 70.3 on w-bodies) hub bore as w-bodies, theres nothing to worry about. if you break studs with a 5x114.3 wheel, you either overtighten lugs or have damaged (or worn) studs.
edit: apparently boostengtp managed to break his studs with stock torque stars lol.
Small cheap spacers on stock wheels won't be that noticeable so a waste of money. Big spacers that will be noticeable cost a lot more.
Not noticeable to you but to the owner you never know. Don't knock it just because you think it's a waste of money.
I said originally "I DON'T THINK". That is my opinion on it, that it's a waste of money. Also my opinion is that it really isn't that noticeable unless the tires are relatively close to the fender, ie low and flush
