Are 2004 GTP's Governed?
my gtp sat at 110 forever tho and i let off thinking it was the speed limiter but i dont do top end runs to save my 4th gear
Supposedly my wife's aunt's 2002 GTP governor was turned off/de-programmed, or whatever, and went 160. I wasn't riding. But that's what she said. I called BS on that.
I don't have to go that fast. I was just curious. I was once told as a teenager. It's not how fast you go. It's how fast you get there.
3.29 gears..
Nope you got that backwards although you would probably hardly notice a difference top end. You accelerate quicker but sacrifice top end by going with a 3.29.
You theoretically will run faster track times with 3.29 gears... .1 faster ET and 1mph slower for the gear change to 3.29
I know for a fact my car has done 131MPH with the mods it has, might go another 6MPH if I had a long enough road to test it on, accerlation is what wins races though.
So you would say that they both top off at the same mph?
Actually a better questions whats the difference between a comp g and standard trans other then the gearing and tapshift? I believe nothing but correct me if I'm wrong.
I have a 2001 GTP with standard engine, have hit about 110 mph plenty of times, it had a bit more so I think top speed of about 125 mph seems right.
