Top swap not making power! Help
the BBV should be hooked up to the top of the blower, to the one you have capped now. Watch my Video I posted it shows the BBV hook up. Under the blower snout you should have only the MAP and the Regulator running off of that.
Do you have anything connected to the bottom end of the BBV? Couldn't tell in the video.
How much boost are you running? what size pulley?
im running a 3.2 pulley 10psi or so. no just the vac line to the top of the BBV the other nipple needs to vent
I did a T on the regulator. One line going under the blower as well as the map sensor. Other side of the T is going to the throttle body. Then connected the BBV to the top that was plugged. Still only have a max of 2.9lbs of boost. I'm scanning with an aeroforce. What else could it be? bad BBV??
and you'll want to set it up with this routing.
top of the sc tree to the by pass actuator to by pass solenoid then to fuel pressure regulator, then the T under the snout, then to the map sensor.
Tb line goes to the evap on the back as shown.
post 48 in this thread page 3 also has a pic of the line from the under the snout, to the fuel pressure reg, to the by pass solenoid.
follow the vac routing for a 98 and up diagram on page 3, evap is right by the map sensor on the back of the sc.
sites not being pic friendly right now.
Heres my map sensor and Evap Canister. both in the front
