krysp432
If there is a valve cover leak will this interfere with the vacuum? If my valve covers leak would that be enough for ruff idle like I have a vacuum hose out?
I accidently put a small crack when doing my LIM replacements, got a just a lil frusterated and forgot about the third bolt on the alt. try to yank off with a small crowbar, and put a small crack on the rear valve cover. -I know I know jacka** on my part- Applied that application that can fix lleaks on metal, been working for a little while. I can hear air being released from under the alt. thinking its the valve cover finally giving out. I have new covers coming in -thanks to dsmuts- and will be replacing both valve covers as the front one is warped and leaking.
