Advance doesn't price match online retailerswhen you get the new uim, advance should have it in stock. have them price match rock auto for it...its a nice discount on it. and youll be replacing the egr pipe sticking up between those coolant ports. the new pipe you put in will be smaller in diameter so it doesnt get close to the plastic.. use a pair of vice grips to pull the old pipe out, and use a 3/4? inch socket (DEEP WELL) to tap the new pipe into the lim.
I called them and they told me they wouldn't price match rock auto. Is it different store to store?i work there? i know what we price match![]()
"If adding oil helps compression, piston rings may be worn or damaged. If so, replace piston rings after checking piston." quoted from:Ok, after soaking cylinder 1 in transmission fluid for about a hour and cycling it several times, spitting out the spare fluid, cylinder pressure is back up to 170.
So next steps are: Remove plastic UIM and gasket, go buy new one, while UIM is off, continue to dry out ports and cylinders, change plugs, change oil, try again and how all is well..
Sound about right?
