Are the aftermarket oe style headlights built alot cheaper than the actual factory ones. I Tried calling several salvage yards and they want between $120 and $150 per side. I can do the aftermarkets for $100 shipped for the pair. I was wondering if i would be better using my factory lens to do the retro if they are built way better and throwing the aftermarkets in just to have light till complete and for possibly selling it. If they are close to same quality then it does not matter. I just want the reto to be the best it can be. If it is worth it i will purchase another set of factory lights. gonna wait for the responces till i order 1 set ot another.
Ok, questions for a single projector setup. I got the projectors and lens and in the process of installing. The question is for wiring. Should i be using the low beam factory wiring for the main power and then the high beam factory wiring to drop the high beam lens. Or, should i run a new power supply and use factory low beams to trigger the relay, with the factory high beam cable connected directly to the drop lens. I have not decided on which H1 bulb/ballast kit or which wattage kit to go with yet. let me know what ya think. If ya haven't figured i am coping driunkie's design with the turn signal in the high beam location, and led's in the corners.
Relays do save your stock headlight wiring from damage but more so it prevents damage to the HID ballasts since they draw a lot of start up current. You starve a ballast of current at start up and it will eventually fail.
I use a 35 Watt kit with my Morimotos. 55 Watt kits aren't recommended with Morimoto projectors because of the increased heat that is associated with a 55 Watt kit. In my experience with HIDs I've never noticed a useful increase in light output from a 55 Watt kit versus a 35 Watt kit.
Thanks geddawngxp, Your explination on the ballast inrush power needs is good enough for me. i was not listaning to those that say( cause it will mess up) i hate genaric answers.
are you done yet?
Just FYI. If you are doing a single retrofit with the morimotos. Instead of using a dremel to cut your hole, get yourself a 2 3/4 (2.75") holesaw. This works great and only takes 1-2 minutes to get your hole.Just make sure your run your drill on high and use light pressure (do not push too hard or you could shatter the lens). Also hace a vaccum or small brush to clean the groove out a couple times while drilling, otherwise it starts melting the dust(not a big deal if you dont mind the smoke). Once i am done i will post pics and more of my how-to's from my experience.
Why would you need to cut a 2 3/4 inch hole to mount a morimoto mini projector?
That is the size hole that is needed to be cut out of the reflctors in order for the Morimoto's to sit back far enough that the clear lens will fit back on. You could spend hours with a dremel and cut a sonewhat oval hole approx the same size to match the projectors shape but the holesaw was just way so easy to pass up
