SliceTheRice
I'm really curious to know what the results of this are going to be - I honestly couldn't guess who the winner will be.
What color coolant do you run in your car?
Also, I think Havoline saw them coming with this one.
I have dexcool.. I think I might change, but then again I don't know. Too many opinions.
its also fairly hard to find non-dexcool coolant. the only reason dexcool goes bad is because there is air in the system and it starts to oxidize and gum up. make sure your coolant system is up to par and the dexcool will run just as well as the old school green.
I know the HOAT coolant in my Jeep is supposed to be all famous for having powerful corrosion inhibitors (5yr coolant too), I've wondered if I could get away with running that stuff. The only drawback is that it's very very hard to find stuff.
Switching coolant from dexcool to conventional is difficult because if you dont get every last drop of dexcool out of your system and install the green, you can turn you cooling system into jelly.
When I look at the bleeder, it's like there is a small screw inside of a bigger one! I don't know how else to explain it so I hope you know what I'm talking about. Do I open the little one to bleed or the big one?
This is G-05. It can be had at any Chrysler or Ford dealership, or Napa usually carries it made by Zerex.
The little one.
i went green after my build ive seen a lot of nasty dexcool mess tearing into gm engines
i triple flushed my system n went green never had issue with green
