Hello, turbo GTP in the house.
crashgtp
Name's Dan, and I own a 2001 turbo GTP. 505fwhp horsepower. Car is for sale, btw! Just thought I'd drop in and say hello!
details? Dyno sheet?
AS requested:
Stock engine, except for cam.
ENGINE:
-Precision Turbo PT67 turbocharger
-#60 injectors
-ZZP Whisper exhaust w/magnaflow mufflers
-PFYC exhaust cutout (no longer functional)
-Stattama Stage 2 turbo cam
-ZZP air to air front mount oversized intercooler
-Powerlog stainless manifolds
-PRJ blue plug wires
-ZZP catless downpipe
-ZZP custom tuned PCM
-180* drilled thermostat
-ZZP stage 1 voltage booster
-Fuel pump rewire
-Walbro custom fuel pump
-ZZP custom dogbones
-ZZP poly motor and transmission mounts
-Tial wastegate and blow off valve
TRANSMISSION:
Fully built ZZP transmission, including:
-ZZP input shaft
-4T65e Chrome Moly Pump Shaft
-Hardened 4th clutch shaft
-Gun drilled output shaft
-Meziere billet flex plate
-3000 stall T/C
-1" GMR chain with 3.29 gears
good god thats wicked man, ever run it on the strip? And welcome btw
Yeah, the old setup with the smaller IC, gutted blower, and before the fuel system was revamped put down 462 and Turbo Tim ran an 11.95 in my car @ 120 on 18psi. ****ty 60'.
Current setup is N/A top end with oversized ID and upgraded fuel system, havent been to the track yet, but put down 505 on 21 psi.
Oversized ID? LOL Just givin' ya shiz man...welcome over...I think you gotta have 20 posts or something before you can even post in the For Sale Section though...but for anyone wondering...for what he is asking for this thing...its a steal.
i'm hoping its not L36 due to it being plastic, there was a monte on here not to long ago that had the L36 with a turbo and it blew up destroyed the whole car
Note that these pics are with the gutted blower and smaller IC which since have been repalced with the N/A upper intake and larger IC respectively.
See that Missing Driver side Headlight!
Thats called RAM AIR WITH A COLD AIR INTAKE SON!
Thats how Florida does it :)
I would take my chances, there is tons of people running l36's with no problems. That was just a freak accident the l36 in my mind is better.
