BoostJunki3
Needs A Turbo
i have 2 setups in mind.....
NIC*GEN V*E85
FSIC*1.95 RR*93 OCT
what would you go with?
NIC*GEN V*E85
FSIC*1.95 RR*93 OCT
why not like XP, Gen V?
or Full Size IC, Gen V?
research honestly...I don't think you understand what you've got going on there.
i thought the NIC cam was meant for those who dont wanna go intercooled?
so i was saying shoudl i go big cam with a better blower or gen 3 rocker'd and IC'd? what am i missing>?
you dont realize those setups are vastly different in how they will perform and how they will run. a NIC setup will NOT be good as a daily driver and unless you know how to tune and have a wideband then youre going to be ****ed. cam or not, an intercooler is a good idea. the only reason a NIC can run such small pullies without an intercooler is because of the stupid amount of overlap that it has. you HAVE TO run small pullies in order to keep boost levels up. its not necessarily a good choice for a cam in any situation.
therefore we are back at this situation: do you want to run a cam or not? how fast do you REALLY want to go?
12 flat or 12.99?
what intercooler you goin with?
Well i will be running one here real soon just have to finish it up. I think its gonna be just fine. You can go with what you want, you know the pricing.
Logan. Put it on your car and make it work. Enough with the selling it and "seeing" if it works or not.
As for the OP.
Just get a S1X or XP and a S2IC from ZZP along with #42.5's and get it tuned.
