'00 GTP sedan, sunroof, system, 4000lb car. 3.4" pulley, intake, 1.9 rockers, log mani, zzp DP, stock exhaust.
I have a 98 gtp coupe and it says on the badge on the door 4500 lbs. Is that rite?
I hate to tell ya man but that would never happen unless the guy drivin the civic had no arms.... just an ls vtec civic would stay right on the side of you nevermind boosted...
Lmao. A gtp will rape a civic any day, dude vtec is just a fancy term for your car doesn't make power till 5500 rpms. Yes the turbo helps, but I'm sure this guys got some mods (didn't actually check but I'm sure he does).
not true because my old turbo '94 hatch on 14psi would destroy 3.4" gtps with ease, 5-8 cars from a 35 roll was typical.
my buddy had a 99 civic si with everything under the sun except turbo. s/c, or n02. i think he ran consistent 14.9
that's why i was comparing the cars, not the motors there Jr.Sorry, but if you threw a 14psi B-Series motor into a GTP...it would be a epic turd. You can't compare...a '94 hatch weighs what? 2,500lbs? Exactly.
an actually good set up turbo honda will spank nearly everyone on this board. if its an ebay setup, thats another story. any real 4 cylinder guy (called "tuner", not "ricer") that knows his **** will run a civic into the 12s with ease on a turbo setup.
