IndeedSS
SS-DD Level Member
You are right...I am going ahead with its replacement...I bought a SNAP-ON Compact-Torque Ratchet, 40-200 in. lb., 3/8" drive on eBay (Excellent Price, $85 almost new (retails at $238 from SNAP-ON))....I also went ahead and bought Engine Tilter LIS48260 from Automotive Tools & Equipment. It was $37.99 (S&H add $9.99).
I used blue locktite on the threads - medium strength and it is service removable. I was able to get a spark plug wire holder from GM for $2.50...I am going to replace the spark plug wires while I am at it...
Any logical steps in approaching the removal of the rear vc, once I tilt the engine a bit forward...The front took me about five hours...I was documenting all the steps so as not to forget anything and at the same time, I can help others with details (i.e., socket sizes etc...)
Disconnect the battery
remove the back plug wires to move them out of the way
remove the alternator and the black alternator bar (most do not put the bar back on)
Loosen the alternator bracket but don't remove the bolts
remove the MAP bracket.
I removed my engine bracket(s) at this time and put them on the shelf.
I think that this should give you the access you need.
Now would be a good time to replace the coolant elbow though. If you do this, go ahead and remove the alternator bracket as it will make removal and installation of the VC somewhat easier.
