Valve cover gasket replacement
Thanks. I reckon it might have been in that range, although I did not have any luck finding it myself.
Finding the torque spec? Yeah I had to pull out my service manuals to dig that up. I didn't see it on any of the quick cheat sheets.
HELP PLEASE...I need to remove the black plate that is blocking the bottom two bolts on the front vc on my 1998 GTP...I do not want to break it by prying it off....ADVISE?
Unfortunately I am not aware of the plate you are talking about and the wife has my car right now so I cannot go out and check. Anyway that you can take a pic and post it up?
You should remove the whole coil pack bracket.
Edit" Crap you are talking about the spark plug wire holder. Just pull up on it.
I did find one piece of helpful information. It appears, at least according to all data, that the valve cover bolts are to be tightened to 89 inch lbs.
  1. Install the right valve rocker arm cover.
  2. Apply thread lock compound GM P/N 1234593 or equivalent to the valve rocker arm cover bolt threads. Notice: Refer to Fastener Notice in Service Precautions.
  3. Install the right valve rocker arm cover bolts.
    • Tighten the right valve rocker arm cover bolts to 10 Nm (89 inch lbs.) .
10 Nm or 89 lb in (7 lb ft) - per the gm service manual
and blue locktite on the threads
Thanks from me too!! I have painted valve covers to install. While I am at it I removed my alternator to have it chromed. Thats another issue, see my thread asking for help. Anyway I am doing fuel rails whil I have everything off. I was looking at it today after removing a bunch of things and wondered about the coil side. Glad I saw this thread. Good stuff!
Well, I was able to remove the vc, clean it, replace the gasket, added some rtv to hold it in place and finally installed it...I tried cleaning the vc but it marginally improved in looks...lol
I sure appreciated all the help from my Forum friends.
I was only able to replace the front vc gasket. It took forever. I looked at the rear vc and did not see it significantly leaking like the front one...The front was a mess...the vc bolts were all laden with oil...The vc bolts at the rear all dry and clean.
Should I go ahead and replace the rear one anyway? How much removing does one need to do for the rear vc?...It looks less tedious.
I did not have a small enough torque wrench but instead I used thread compound and snugged it by hand. Might have to invest in a small torque wrench. Yes, the black plate is the plug wire holder for 1, 3 and 5 wires. One of the tabs broke on mine as I lifted it. I am ordering a replacement from GM...It is about $2.50.
Sorry you broke the wire holder, but pulling up on it is the only way I know of to remove it. Over time they probably get brittle.
Doing the rear one is much more tedious. You can do it, but it will take more time. Congrats on getting the front done!
i assume youre meaning the service-removeable loctite... as there's actually a few different formulations of loctite that are blue... :o
All data didnt specify, so I would believe it would be service-removable.
As for the rear valve cover gasket, I would personally go ahead and replace it. But Im also the sort of person that replaces headlights, fog lights and such in pairs even if only one is dead.
I look at it as if the front gasket failed, the rear cover has the same material and will be more prone to failure and you already have the gasket. So you might as well use it.
You are right...I am going ahead with its replacement...I bought a SNAP-ON Compact-Torque Ratchet, 40-200 in. lb., 3/8" drive on eBay (Excellent Price, $85 almost new (retails at $238 from SNAP-ON))....I also went ahead and bought Engine Tilter LIS48260 from Automotive Tools & Equipment. It was $37.99 (S&H add $9.99).
I used blue locktite on the threads - medium strength and it is service removable. I was able to get a spark plug wire holder from GM for $2.50...I am going to replace the spark plug wires while I am at it...
Any logical steps in approaching the removal of the rear vc, once I tilt the engine a bit forward...The front took me about five hours...I was documenting all the steps so as not to forget anything and at the same time, I can help others with details (i.e., socket sizes etc...)
