I emailed Will (overkill) about 3 weeks ago, and still no response. I am going with Intense.
im planning on ordering a pcm in the next few days but idk which to go with. overkill or intense? overkill seems too hard to contact so i think im just gonna go with intense.
I had trouble contacting Overkill (he still hasn't replied and it has been over 6 weeks! So i went with intense and just put it in over the weekend (along with the Intense Fenderwell Intake kit, and plugs, and other little things; as part of their Stage one performance package). It is absolutely incredible difference, and their customer service is incredible.
I definitely recommend going with Intense!
alright cool. that makes me feel better. and i ordered the custom pcm so im thinkin that its going to take a lil longer for me to get it. i cant wait.
They are really fast, it shouldn't make much if any difference that u made a few adjustments. They have to put the vin in all of them, so they all need a few things (so im sure its just a keystroke for them to adjust it). I only have the GT and it is incredible difference. Hope you have fun with it!
Im at the INTENSE website and about to get a PCM. I want some information from you guys. I have a 2005 NA engine (L26)with Stock internals &...
1.Should i leave my timing tables stock or choose the 1* option for $20 more?
2. what should i choose for my transaxle shift settings? Leave at stock (+$20) or raise to approx. 6000RPM($0)?
3. i am also going to be getting a HV3 Intake Insert in the upcoming months. should i have the PCM programmed for this mod? will it have a negative effect if its tuned for it and its not installed until a later date(HV3)?
Any input on which settings i should choose would be great!
im thinking about getting a ZZP PCM because i also want the HV3 Upper intake insert.i figure i should just get both at once, right??? i think those 2 + my CAI should do the trick.... just hoping for around 230hp anything higher and i will be pretty happy. ~ 05 Base GT GP
zzp pmc's are not that good.
bad shifting on the trans.
