dblackston
As the title states, I would like to enlist the help of fellow GP enthusiast to help me confirm what all has been done aftermarket wise to my 99 GTP based off of folder full of receipts and invoices. There are a few obvious parts and components that I can see clearly do match up to the paper work but needing help confirming the rest. I have a long list of what I was told has been done to the car along with a pile of paperwork...my issue I guess, is that for what all has been done to this GTP I expect more power out of it? It is quick for sure but being modded to the gills, figured it would damn near fly if wings were added. I would also like to know for repair/replacement instances and of coarse what all I can do or add as I can never leave well enough alone and seems like EVERYTHING has been done on this car already.
Can definitely upload better pictures if that helps as well.
Thanks in advance!!!
To start, here is a short list of what I was told is done as well as what I can see (sure I am forgetting or missing something):
Upgraded pulley for the supercharger (obviously not stock, but has no markings..any way to check size, is it as simple as measuring the diameter?)
MSD coils
Exhaust (receipts for both magnaflow mufflers and SLP? haven't yet looked under the car)
Headers (there is a sticker for TOG headers under the hood, anyway to confirm brand as did not find receipt)
Fuel/air chip (not hooked up currently but in the glove box as well as a receipt)
Baer Brakes
Intercooler (stage 2 zzp according to paper work)
PRJ Fuel rails (paper work says 42lb injectors, any way to confirm?)
BMR Braces front and rear
Fender braces
ZZP dog bones
alternator rewire kit
Python alarm system (key fob batt's are dead...might have remote start, anyone with experience here)
Below is a smaller list of what may be done but do not know how to confirm (also have been trying to track down original owner as I would love to pick his brain on the car)
-How can I determine if the car is indeed cammed? (paper work states zzp XP cam along with upgraded rockers, springs, ect)
-Any identifiers to let me know if it does have zzp aluminum heads as an invoice states?
-Found invoice also for DHP tuning...anyway to confirm, will the PCM have branding or markings?
-Upgraded gears (3.29 iirc)
-ZZP trans rebuild according to paper work (will this just be internals or with the case have any markings?)
-Meizer electric fuel pump (cant quite see at quick glance)
-Smaller tooth reluctor wheel (first...what does this do anyway and does it matter if it is there or not?)
-High velocity throttle body? found receipt only marking I find says "Hitachi" and seems to have a spacer?
Again sure there is more here that I am missing and is a lot, that is why I am asking for help even though I am asking alot. Thanks
Ps, something else I found odd...all this work and parts and no indication of a way to monitor KR? There are autometer boost, water temp and oil pressure gauges in the car so unless another gauge was mounted else where or it was monitor through tuning software (DHP?) I dont see how this may have been watched. Maybe he didn't with all the supporting mods to reduce KR (headers, inter cooler, ect)?
MSD coils
Baer Brakes
Fender braces
ZZP dog bones
