SubwayGuy
Who is this guy?
Re: Subway's GT: Top Swap Parts Are In
Everything will be done myself. I'm not spending more money by dropping it off at the machine shop. I'm lapping the valves and putting new valve seals on. After I clean down the heads, I'll check the level. I'll take the valves out and wire wheel the top of the head to get it all clean.
I'm with Scott...didn't see the Sc idler stand or the specific bolts that go with it. They are a slightly different thread like 1.25 vs 1.50. Personally........... I'd drop those heads off to the machine shop, have them tanked, fluxed, painted and assembled with a valve job. If you wanted to plan ahead, have the seats machined to 1.800 so that you had the correct pressures on with aftermarket springs.
