Some more top swap questions! Yay!
Ya it's running decent at girst start it did a little idle searching then it mellowed down to 850 with a little searching like plus/minus 50 rpm i have a few check engine codes obviously. One is for a case learn. I ran it up to operating temp. 180 and then killed it. So far no coolant in the oil lol
Sent from my LG-D851 using Tapatalk
sounds good. the crank learn will fix up that idle and smooth it out more.
a few more little things and you'll hear it whine.
it does. if it was wired up wrong you'd have a code for it for sure.
theres a way to set it to read boost, ive not figured it out yet, nor do i care really. only time i see the boost is on a scan, and even then i dont look lol
Well torque app was saying my vaccum was about 18 which seems about right at idle so im assuming i wired it correctly
Well the vaccum gauge on toque reads vaccum so it was at 17-18 vaccum which is right around where my l36 read at idle so im assuming since the supercharger isnt working that sounds right. Right?
Right so if i dont have the sc running 18 vaccum would be normal at idle correct? In which case i can assume my map sensor is good
Ya i was gonna try to find a shop that could just do both lol i have to go back to work tomorow and need my car haha. Tonkin i am using a reptile tune so no it is not the original pcm
Ya so i think in the a.m im just gonna try to find a shop that can pull the hb off and do the case learn
