Engine help
did you have any vibration before the engine pull driving?
and its not supposed to come apart either, unless you ripped it apart, but i think thats kinda hard to do really.
A little vibration, I didn't pull it that hard
I pushed it back when I took the wheel bearing off
How do I know when they go bad, cause I still have the old ones and I can put it back in the car
when bad they vibrate when on the gas, when they first start to go bad its a light vibration when light on the gas, nothing felt when hard on it, but as it wears more they will vibrate bad when your on the gas. you feel no vibration when coasting off the gas.
if you ever felt a bad U joint on a rwd car its the same thing. only you have more U joints in side the boots of a fwd axle.
Ok, so I can put the old one back on then
I bought the transgo shift kit and it just arrived yesterday
I can just follow 02navyblues posting How To Install TransGo Shift Kit 4T65E right
I've used something as simple as a ratchet strap. Looped around the differential (not axle) and hooked onto the top of the firewall.
Thanks
If it wasn't cause of your "how to" I don't think that I would of tried it
It wasn't that bad of a job other than working in the heat, that is why I tried to start early in the morning
If you didn't print off the how to ... maybe have it on hand next time. Always.. if you come up against something like the bracket that doesn't say remove oil filter adapter to get bracket, pop online and ask the question. Tons of good people here that know how to get around something like that.
it was pretty funny, i was putting the engine back in and bill calls me, i pop him on speaker phone and im under the car working on the tc bolts, im clicking the fly wheel with a screw driver and i ask bill so what am i doing now???? he pauses to hear whats going on and says, oh you doing t/c bolts, moving the flex with a screw driver lol even by sound alone he knows what your doing lol
:th_biggrin2:
I just want to thank all of the people from the site, for all the help that I have gotten on everything that I needed help with
And for all the help that I am going to get in the future
Thanks again
I have the engine on the stand and have the headers off
This is where the bolt is broken
Cant see it that good, but the broken bolt is in there
Can someone tell me what size of drill bit and tap I can use
I can get some of those extractors from work, not the hole set but 1 or 2 of them
Anything else that I should do to the engine while is out
just clean it up good then take it apart to re gasket it. who wants to work on a nasty parts?
you can also paint it and make it really clean looking.
paint it all lol
started out like this. then all new gaskets and primer and paint.
i used duplicolor high temp paint and primer.
i used a wire wheel to get the rust off, sprayed it with brake cleaner and primed it with a whole can, got a light coat and a good coat out of the can.
yellow was 3 cans in all. but i got 1/2 a can left, and 2 cans of black, and i have more black left over still.
