Scottydoggs
Killa Bee
Fine:th_embarassed:, I will tell you how I broke it
I was trying to separate the engine and trans, but had forgotten to take the 3 bolts off the torque converter
I was working outside and it was about 90 degrees and I was tired
Junk yard it is then
that blows. it was hot as hell the two day i was ripping and replacing over. at least i was out of the sun in a garage, but it was still hot as balls.
if your heads are ok dont touch the heads, i only did them cause i top swapped a n/a block. had no choice in the matter.
i'd do the lower conversion kit. a lim gasket kit, upper plenum gasket and new valve cover gaskets. new coolant, oil and a filter.
