Booba5185
You have a pick n pull type junkyard around? Time to go check them out. There will definitely be 00-05 Impala brakes there, Monte Carlos had them, Cadillac's had them, they're all over. You can always test fit them on a GP while you are there to make sure they fit. You might even be able to buy JY rotors and have them turned to save money (that's what I did).
Once you drive it with any of the upgraded brakes you will despise the stock brakes. You may be satisfied with them now, but you'll see. $300 is MORE than enough to upgrade your brakes.
