97 GTP The White Ghost aka Pearl
get a box of Q tips. then spray some brake cleaner in the cap of the can, then dip the Q tips and clean those injector holes up real good. use 2 Q tips or even 3 at a time.
you'll go through 50 Q tips easy. maybe more.
How about soaking them in cleaner?
Never mind this question I read it wrong
through that hole is your pistons. dont drop anything down there. if a little of that sludge falls in its ok, it wont hurt it.
I was just looking at my fuel injectors very closely and this is what I found.
I hope none of these fell in the fuel injector holes. There was one of these totally missing from the end of the injector. I found this one near one of the holes.
What should I do now? Do I need to take the heads off now?
its plastic, if your that worried take the spark plugs out of the cylinders that the injectors ends broke off, and then crank the engine over to blow them out. wait till the lim job is done to do this. take all plug wires off the coils so it cant fire up and run.
you also need to clean them injector holes, a chunk maybe in the hole still.
Ok cool! Where can I get those plastic ring replacements for those injectors.
Can I reinstall the injectors without those plastic rings?
you broke em, you got what you got, just re use the injectors. you cant fix that.
if you want new O rings the parts store has them. cut the old ones off with a razor. oil the new ones and roll them on, re oil them before you re install them, helps them slide in.
Here is a few pics and a video of my LIM job. I guess it looks typical of bad gaskets. There is slug in there. I was thinking about how I'm going to remove it. Enough talk here is some pics.
Here is the video.
