Budget Comp G. 2.5" pulley = no belt slip
Re: The Slowest/Cheapest/Should be Ashamed of Budget Comp G @ $3648.89 New Pics!
Trans tune is off. I just reflashed it and that should take care of a lot of it. It was dry but I did spin. Just fyi my aeroforce told me i was running a 12.8@110
Well if i run a 14.7 im demodding my car lol
Over a second with a tune, that sounds a hell of a lot better. Hope its equates to that next time on the track! Goodluck!
The AF is always WAY off.. Mine tells me I run 13.1 at 115 or some ****.
That's what it said before I went to the track. I'll see what it says tomorrow when I get to drive it.
I ran a 14.6 with a bone stock topswap... ported gen 3, L36 block, and a 3.6 pulley and e85. 14.6 at 97 MPH LOL
Its all in the driver mod ;-)
What Josh said. You can't really base your 1/4 time off the Aeroforce. It's not very accurate.
Just get back to the track and run 12.99 :)
Re: Budget Comp G @ $3648.89 Disappointing 1/4 but issues found
Well I'm revving higher now and not hitting the limiter I think. It's hard to tell when it's wet out but I think it went up to 6300
Shifting issue fixed. Pulled harder than ever then I think I broke my input shaft. Trans swap in progress as soon as the kids lay down to nap
good luck man! At least you got one good pull.
Trans should be in by tomorrow. Then this one will be getting built
Thats rough. At least it seems like its running good now! :-)
I didn't even mess with it yesterday. I'll probably pull the trans today then put a 7/8 chain and 300m in the other before it goes in
It'll be much better soon. I was hitting the rev limiter at the shift
