Budget Comp G. 2.5" pulley = no belt slip
Re: The Slowest/Cheapest/Should be Ashamed of Budget Comp G @ $3648.89 New Pics!
I'll take the hood, wheels, and engine mods since you can no longer drive this..........The shaming will be painful.
Everyone wants something.
The track is a cruel place, ain't it?
The bright side? You're a full three seconds/20~ mph faster than the guy above me, Dan.
are you gona have brian dyno it?
Possibly. I think I have my issue figured out though so I'll be hitting the track again
Turned the rev limiter up and upped the shift points and a few other small changes.
Where you using tapshift? I was playing around with this the other night with my aeroforce. In drive i was hitting 14 flats consistantly. Using tapshift, shifting it at like 6k i was seeing 13.7
No with tapshift it shifts slower for me
I thought i heard that its always slower with tapshift....
Weird. Dsmuts besides your trans sucking asshole what does your tune look like afr and timing. The difference in power from running a little rich 10:1 to 11.6:1 is huge
afr is about 11.5 18* timing on a 3.0 for that run.
Jesus your trans must be absolute garbage or you spun tires down the entire track. Was is wet out?
Trans tune is off. I just reflashed it and that should take care of a lot of it. It was dry but I did spin. Just fyi my aeroforce told me i was running a 12.8@110
