What did you do to your Car today?
Status
Not open for further replies.
Got the newest member to my w body fleet running and a little cleaned up..still need claybar and wax to refresh the 20year old paint!!
Sent from my SCH-I545 using Tapatalk
I just replaced a pump in a 02 at work. From my experience with the washer pump it is right by the tire behind the splash gaurd. Not easy access behind headlight. Not in a gp anyway.
It isn't easy, but if he only needs to check for a leaky hose, this way is better than pulling the inner liner again. Here is a pic of when I did mine, and you can see that you can just get an arm down to the pump; I tried this way but my well endowed arms are just to big. :D
That would be so cool with rwd and a turbo lol love that body style
Plan is to to turbo it next spring..not sure if I will put a 3800 in it or keep the 3.4...in researching that lq1 loves boost but parts are hard to.come by...we will see
Oh I have it easy. On a lift, pull the wheel. Easy unless the tank is full then it is a mess.
3100 with a 3400 top end, turbo kit, and meth injection.
I know it's not exactly the same. I'm just saying there's nothing wrong with modding something that is not a 3.8 lol.
Pretty sweet! Yeah I am leaning toward the 3.4 since I am already modding my gtp..should be fun either way :)
had to go and re flash my tune again due to the codes i wanted deleted were not deleted some how. not sure but the off board tuner worked like a champ one more time.
SD I'm not hankering mods so much now, the computer end sounds like a hassle. That vid the other day sounded good but it was like I could hear the extra doors holdin you back lol.
Blue02, I'll trade you hour for hour, come on down. Your rockers for my trans swap. I have rockers for you.
I delare my diff toast after seeing the pan contents last weekend and the noise and sloppy shifts I'm getting. Didn't take a pic on purpose because it was so gross, but I do still have the filter if you're into gore porn. Probably a three inch square area of friction material then the magnet with thick silver slime covering along with amber-esque fluid. So I must begin the process of nabbing the good trans from the 40th, then doing the ol swaperoo. Burnouts FTW. Think I'll keep the engine I have in there for now anyway. Theroetically, it has 30K less miles since built. 106K rebuilt vs 135K OEM if the stories hold true. Anyway... yay but I should be able to access a rack thank goodness, and do it near my toolbox.
Status
