In the state I live in emissions are strict and I cannot be without a cat.
Also, what do you think caused the clunking?
Clunking?
Subframe bushings.
ShOuld do strut mounts too
They will fit and you'll have to do no modifications what so ever. You might want to look into doing the strut mounts as well.
Are you sure about that? I don't want to change parts I do not have to.
I have been hearing tons of things cause clunks. So far I have my done my LCA's sway bear links both front and rear, both motor mounts, tie rod ends, and front sway bar bushings thinking they could be the culprit and I am still having this issue.
From what I have been hearing it can either be my struts, strut mounts, sub frame bushings, and even the steering shaft.
I am ruling out the steering shaft because I don't hear any clunking when turning. I also don't feel any clunks through the steering wheel either.
The clunking sound comes from the passenger side of the car towards the glove box. Only happens if the car has been sitting for awhile and when I accelerate from time to time especially on an incline. Also it will clunk when going in reverse again especially on an incline. The clunking is not constant and happens at random, but I at least hear it twice every time I get in my car.
If it is the sub frame bushings? is that a large job or can be done rather easily on jack stand or a lift. How much labor is involved?
Hmmm
This is another area too, if you haven't done it.
I should replace the struts too along with the mounts. They are original and have 80k on them. Although that will have to hold off as it is quite pricey for FE3 struts. I just want to eliminate the clunking first and if its subframe bushings thats a much cheaper fix. I just want to make sure thats them. Clunking upon acceleration could have been many things and I have eliminated most of them. I am hoping its the subframe bushings as you said if its an easy job. I will get to them eventually but I need to save up on some cash first as I already spend a bunch on parts in the last month. Would you say a subframe busing replacement take more time that a strut replacement?
What do you think caused my P0420 code. I cleared the code two days ago and it has not come back. I find it hard to believe its my cat as it only has 80k miles on it and my exhaust has not foul smell or white smoke. Also not sure if it is the O2 sensors either because my gas mileage has been consistent 10-16 city and 25-30 highway. Also th car does not hesitate or has had any loss of performance.
The code came on on the highway on the 240+ mile trip back home two days ago.
Why Fe3 struts? You can get KYB Excel-G's for cheaper and they are just as good, if not better. Not everything has to be OEM.
Not enough of a difference that you would notice it on a day to day driving...or even on an autoX cross if you were to do such a thing.
it took you 2 hours? takes about 20 mins for a brake job dude
Did you grease the slides and where the pad sits in the bracket?
They make a special high temp synthetic brake grease or something like that, but I just used wheel bearing grease on my moms car because its all I had lol.Not to thread jack. But what grease should you use for that I'm about to do mine
