darkhorizon
You might see 113 to 115 in the 1/4 if you have everything on point which might scratch at 11s.
Fyi I trap 116 in the 1/8 with my current setup.
I'll believe it when I see it.
390 to 420whp.
I went low 120s with the same setup with 500lbs less but I was flowing alot more air than you.
i cant wait to show you freaks what a talldeck 3800 does in my wagn
So your guess is I trap 113 mph in the 1/4 ?There is no estimation going on here... this is hard math with nothing to guess at.
You know I trap 100 mph in the 1/8. So I'm only gaining 13 mph is the last 660 LOL !!
Come on man. I have to trap no less than 119 mph and most likely over 120 mph ! unless I have to deal with a NASTY head wind.
Also a strange issue... can't get car in 1st gear. It starts in 3rd gear or maybe Overdrive when in D, and when I put in the shifter in 1st, I'm in 2nd gear.
I see you haven't been properly introduced to 4t65e 3rd gear yet. Lol.
You're not trapping 100... hell I didnt and I was rwd running 10s on a stock motor and trans.
I think what a lot of this is coming down to is dyno/drag slips. No one is going to believe you're doing what you claim because it's been tried before and it hasn't had the same results. Prove everyone wrong...get legit info.
I will take a look see if there is slack.I haven't ready your entire thread. If the trans was swapped, swap the arm on the actuator of the trans...otherwise go tighten the trans cable bracket on the trans. If the trans was out..and rebuilt with parts from a few.. your rod and manual valve are incorrectly matched
Don't take me for a fool. I've been tuning and racing since 1998. Mostly street cars on pump gas but in the last 5 years doing more and more race machines.
Unless I break something at the track I will be coming back with the timeslip. Then you can stop doubting LOL !
