TwinV6GTP
There is clearly something you don't know about these injectors and the dutie cycle reported. I'm not sure I feel like sharing, it won't change your mind obviously you are dead set on your opinion.Bro, a 2.6 pulley will BURY a stock maf, screen or not... stock injectors at even 15psi more base pressure is not going to even get you a 38# injector.
"30% more power" is not happening just because a turbo is putting air in your motor.
I'm not sure what you read into my post and how you understood it. But the turbocharger did put 30% more power to the ground at the same boost level on my set up.
That is because I am not intercooled.
Non intercooled boost is less dense and much hotter. 16 psi non intercooler does not provide the density of 16 psi intercooled.
The turbocharger via the massive intercooler in front is 75-80% more efficient than any core you can sandwich between a supercharger and an intake.
This is why 16 psi of turbocharger power feels so much more than 16 psi Supercharged non intercooled. PLus the fact we have tons of parasitic loss in the M90 !
