42# injectors for an '04
Sudden
I searched and read all I could find on injectors for an '04 GTP but I would still like the opinion of some people that have them. I have 1.9 rockers, a PLOG, a 3" catted down pipe, A S2IC from ZZP, and a 3.4 pulley. What brand of injector seems to work best for our cars.
TIA
If you do I always suggest the 39# mustang injectors. They flow a bit higher than 39 usually and are a cheap direct drop in.
As dh just said cobra 39lb are a great option cheap easy to find and ev6...39lb is at 40psi so they are actually 42lb ish at 43.5psi...bought a low miles set this morning off eBay for $137
I was gonna say, I thought it was the same or at least very similar :D Just a pain not having an access panel to the fuel pump right in the trunk.
Racetronix makes a rewire that plugs in underneath the vehicle by the gas tank for 05+ with no access panel. Still has the small wiring between that connector and the pump but at least it replaces everything else.
