42# injectors for an '04
Lol good question, I'm on stock injectors. Now I posted about injectors ;P
Sorry, forgot the main point in this thread was about injectors. He was asking about running a 3.2 so I instantly thought 'knock' but injectors, from what I've read on the forums and other sites, anything under 3.0 requires injectors. Thats what ZZP states for both the 97 - 03 and the 04+
I don't have a hot cam, I only have rockers and a full I/C. Will is going to do the tune and send me injectors. I'll be better off for sure.
watch out for the injector spacers i had them leak bad several times from the top o ring blowing out lucky my car didnt burn down spraying gas all over a hot motor , i took some small plastic hose / tubing cut to the length as a sleeve to prevent the o ring from blowing out giving a tighter fit an u can run 2 o rings on the bottom if u have the double groove on the injector for a better fit
Receiver my injectors from Overkill. They are GN 44# with height adapters. I can't get the adapters to plug into my ZZP fuel rail. The adapters don't have a ridge to help hold the o-rings in place and they want to roll one side down the adapter. Anyone else know of this problem?
