What did you do to your Car today?
Status
Not open for further replies.
ever since the ic install. I'll have it sorted out soon enough.
the sig doesnt say but if its a zzp core id pull it apart, split the plates and reseal the core.
2 out of 2 zzp cores ive done have had internal vac/boost/crankcase leaks from a ****ty rtv job
half the time you find people cut out the lower gasket to the square opening of the upper instead of leaving the 45* shoulder near the T stat and get a vac leak.
i cut the 2x3x6.5" block of aluminum for my new billet oil cooler/APR/remote filter adapter and i finished tig welding the new aluminum radiator core support for the WaGN
discovered i couldn't fit a 3.5" DP past the steering idler arm
briefly debated going to a 76mm
Looking for insurance quotes for michigan averaged 275 a month for liability.....****
Sent from my HTC Thunderbolt using Tapatalk
Hmm, mine I just put on is having issues with a Vacuum leak. I can't trace it down yet tho. I'll keep this in mind tho if it needs to come off and do this for added security. Do you use the grey Perma tex or red?
I pay 212 for full coverage here in michigan. I'm 24, (be 25 in may) and hoping it goes down. I don't have health insurance though. It used to be 182, then next 6 months was 192, then next 6 was 212. They keep raising it. Fml. But I went with esurance(online), that was the cheapest I could find at the time. I really need to start looking again.
Realized I have a bad case of the Mod bug... I swear dumping money into this thing is so easy to get into, but hard to stop! I'd imagine that's what meth heads feel like lol
Sent from my Galaxy Note 3
Nice, Well Geico got me down to like 175. I emailed statefarm seeing how much mine would go up if I transferred up to Michigan. Maybe I should get a pedal bike.
Good luck especially if you plan on moving to Wayne County... Our insurance rates are amongst the highest in the county smh...
Status
