I just drilled a hole in my oil neck for now.
There at 2 holes hear as well. One is hard to see, but it is smaller and shinny.
Okay I see them, now should I drill and tap where that picture is, (front left) or do I need to have it near the 'a' & 'n' holes?
Ok guys for those that can help I have a gen v sc, zzp gen 3 ic modified for gen v, ported lim for ic and N* setup with evap and egr.
my question here is the rear and front pcv are blocked off by the ic. I may be able to get the rear pcv to function by modding the ic. But here is where I am confused.
Some say to just block off both and run a breather but that makes me wonder how will the rear function if I do a breather in the front valve cover?
Also I want pcv to work due to emission so breather I want as a last resort.
So my question here is if I get the rear to function what dp I do about the front.
Tap into the oil neck of the valve cover run a hose to the same place I am running the rear pcv?
Between the tb blade and after the maf? Both front and rear?
Hope you guys can help will be doing this later today off work.
