Fivefingerdeathpunch
Service vehicle messages are normally for oil changes/tire rotates stuff like that on many cars. More so with honda/acura/toyota/nissan.
You already know it must be something related to your latest project DogBut nothing needs servicing...I've checked all that to lol
Correct me if I'm wrong but to my knowledge when it says to service the vehicle it's usually just some type of trip meter that after a set amount of time comes on to remind you of maintenance related things. It's not telling you something is wrong but reminding you to change your oil etc. It's totally unrelated to you SES light. At least that's what it means on my Girlfriends Corolla lol.
Nothing like changing a tire on the side of the highway at 5:50 am in the rain. Luckily I made it under an overpass. Front right went flat so I was going to swap right rear to front and put donut on rear. Lug adapter cracked when I was breaking rear lugs loose. Had to put donut on front and tighten as good as possible and limp the remaining 3 miles to work.
I'd say clean the contacts on the relay and see if that helps, and check the resistance on the relay coil to make sure it's not open.
where is that relay at?
