?? Couldn't I lose hp or something not to sure on the difference between n/a cam and a gtp camI'm running a na cam
I would like to find out before I put it in, I have to wait till Friday till I get paid for more parts but I do need to figure out the transmission problems as well, not sure if I will just get it fix and wait a little longer for more cash to get the rest of the parts but I do need to get my car running soon lolYou can run an N/a cam in these engines.
TazMagister or whatever his name is on here is running a GT1 cam in his GTP.
While the engine is out, put the cam in now.
Sorry ment input shaft, and the gasket for that if there is one?Input Shaft Gasket?
Are you reusing those heads?
Either way. Brake cleaner on a rag and just keep up with your oil changes and overtime it'll start to clean itself out and pour oil down the lim etc to attempt to clean it out a bit and then drain and change the oil.
That's exactly what I was thinking to do I found some one selling the nic set up for 700 thats everything should I just get it?
Well what's the point in spending even more money on a cam and heads etc since you've already have those...scratches head.
