What did you do to your Car today?
Status
Not open for further replies.
Replaced both front wheel bearings, the endlinks and the bushings on my GMPP front bar.
[/URL][/IMG]
[/URL][/IMG]did this today...shouldve been an hr job but as usual it turned into longer....Fbodys
Are those stock sized rotors, or are they larger? I like that it fits under those rims, because that's what I have, and now I know I can do the F-body brake upgrade. :)
Putting on a HD lip. How the hell people are using just 3m tape for it confounds me, it isn't holding it whatsoever for me. Going back to Ace for more screws and washers. I'll post pics later
what is in an 08 GP base that is in the front center underside of the car.. cylinder looking.. and would cost 800 some bucks to replace.. it sits in the car on its side so it's not the oil filter... or is it???
also... anyone else have trouble with an unlock button not working on BOTH key fobs? but all the other buttons work.. just not the unlock button...
i haven't seen it yet either or i'd have pictures... just the girl said the last time she went to get an oil change the guy brought her out and said this (this cylinder kinda thing) needs to be replace... and said something with the steering with start being hard when it really needs to be replaced..... last time i was under my gxp there wasn't anything cylinder in the front except the oil filter......
i'll be back over at her place later on today after shes done working and i'll see if i can't see what she's talking about and snap a few pics...
no sir those are 12" rotors...bought them from brakemotive off ebay...u can actually run 16s rims with this setup. now i really want gxp rears..
The rubber insert inside your remote is junk we replace dozens a month. Replacement remotes. Com I think is where we get them
Sent from my SPH-L710 using Tapatalk 2
Just got back from the tint shop, ended up going with 20%. Later today, I plan on putting it in the garage to start working on getting the original exhaust tips off in preparation of my new dual stainless steel tips arrival
Yesterday I washed it with dawn, clay barred, washed again with dawn, and cleaned/waxed with black box. Took a while but looks good :) I really want to get rid of the front plate bracket...
Yes, it would look ten times better if you did. I am not sure of that year car, but can you get a filler plate for it? Car looks good
For the gxp to get rid of the front plate just a drill and drill rhw little rivets out. Its what I did. U can make plugs for less than 10 bucks to fill the tiny holes and it will look way better.
Actually this was yesterday, but I purchased another set of GXP wheels. Currently running four 8 inch wheels! Sn: reset the tire pressure monitoring system. Its pretty cool how it beeps the horn at you kinda like those new Altima's.
Status
