Gtx has a turbo!! lol
Re: 98 gtx and 97gtp to make one going to nic cam and comp push rods this summer:)
egr won't stop it from starting unless it has a massive vacuum leak
Alright I was just wondering but I'm going to charge my battery today and fix my spark plug gap and hope my car starts up
Ok so fuel pressure on my car is 49 and drops down to 40/39 now it should be 50 44 right? Would that be a problem? I hate this rain btw lol
48-55psi KOEO.
Sent using Tapatalk 2 from my GS3.
Going to jack the car up and try to change out the filter see if that works
Alright so weather has been kinda §hi+ and I have no light in my garage because its broke, just waiting on some sun ,but yeah just wondering what do I need to install this nic cam and ported heads right now I have the nic cam 105 comp cam spring not sure on the posh rods but can look later I might get ported ones off vlad that are L67 ported, si valves, vitton seals 105# besides that what do I need my gaskets should be good seeing how I haven't had the car started
Ported heads from vlad should I get them?
It's sunny finally :)
The rusty 98 gas tank
What's the exhaust ports look like?
what are you trading for them?
So went to start car and nothing still won't stay running now that I changed the fuel filter and re gapped the plugs it runs longer but not to much had it run for maybe a minute saw a little smoke not sure if that was oil burning off something it was coming from the back passengers side also fuel psi is going 50 and dropping down to 42 I did see a little gas where the filter is but going to make sure its tight what would be keeping the car from not wanting to run there is no codes im changing the o2 sensor to the new one I have laying around to see if that helps
Does it stay running if you hit the gas? Have you tried unplugging the maf? I'd trade.
No its a new one haven't tried doing that but it will run if I hit the gas then it wants to die after sometime
Re: 98 gtx and 97 gtp to make one ( car still wont start)
Ok getting chillys for me and the girl friend right now will try right after
Alright tried that and didn't work I don't want to spend my money and take it to someone:/
So it'll stay running if you keep giving it gas? Try keeping it running as long as you can and see if it'll throw a code.
