What are you using to monitor those readings?
Does the car have a tune?
I see you have no egr and no cat, both of which throw codes and will affect how the car runs.
Running 91+ pump gas?
WOT timing is more important than your timing at idle, which 15 is like warm up idle low, should be alot higher sitting still when warm.
ya my thoughts exactly, but i havnt heard anything bad about torque so i figured ide give it a shot. Ill compare it to what we read when i go to bills and see how accurate this thing actually is.Using a phone app to monitor a car in my opinion is stupid, so right now its really hard to say what the real numbers are.
A scangauge or a tuning software could give us real numbers and a wideband o2 sensor is the only way to figure out real time WOT Air Fuel Ratio.
Sweet smelling exhaust? Old Bay Seasoning in the coolant/low coolant? These would indicate a failed LIM gasket, which could cause issues with combustion. Maybe pull one of the front spark plugs and check out how healthy it is.
Dirty maf sensor.
Dirty throttle body.
ya my point is they have been recently replaced, things probly have 1.5k on themAs long as the spark plugs have less than 15,000 miles on them, I wouldn't worry. We measure in miles, not time (though, I doubt you drive 7k mi a month). They aren't fruit.![]()
ive replaced one and the rest seem to turn freely anywayHave sticky pulleys been known to cause kr?
i dont think so and im pretty pos that is why. Believe he just made it so the light wouldnt show.Did Bill delete the cat diagnostic self test? If not that would explain the bad gas mileage because the cat test will get stuck in a loop and cause your car to dump fuel. http://www.grandprixforums.net/remo...1-newer-pcms-things-you-should-know-7092.html
lol no, no, no...Exploded lower motor mount. Ummm. Low oil. Dirty ground.
yea its reading halfway mark, 99 celcius on torque so thats 210 fIs your temp reading right? My coolant temp sensor went bad and my head mileage went way down until i replaced it.
