Scottydoggs
Killa Bee
wow seems like a lot of work.
not that bad really.
if you know your way around a engine and feel good about taking stuff apart, its a 3 hr job first time out. thats taking your time.
The other bigger black one is for the NA map sensor and so is the little blue one.
The little blue seal is for the MAP sensor.
flushing coolant is easy. take the t stat out, put the housing back on, leave the hose on the t stat housing, now take it off the upper rad, push it down to the ground.
open the rad, put a hose in the rad, turn it on, then fire up the engine, all the coolant will pump out the upper hose to a bucket or the ground, as your filling the rad with fresh water, run it like this for a few minutes, usually till clear water comes out. then take the hose out, turn it off, then run the car till no more coolant comes out the upper hose, then turn the car off.
put a new t stat back in hook up the hose to the rad, then dump 1 gallon of straight antifreeze in the rad, not the 50/50 crap. start the car, fill the rad with the hose.
let the car idle, rad cap open till the fans come on, then open the bleeder screw on the t stat housing till a stream of coolant comes out. then shut it. top off the rad if need be, cap it, your done.
waiting for the fans to come on lets you know the engine is hot enough for the t stat to open, some times you will see the rad level drop as well. that would be the time to bleed the air as well. because it opened and took coolant from the rad to fill the engine with more coolant.
hell even with antifreeze in the car, let it cool before popping the cap, same thing, it can erupt on you.
