Nope Read the thread called safely modding your 3800 and it will tell you every thing you need to know.
I was thinking of buying a 1" supercharger spacer from ZZP. I was wondering if its worth it or not.
I didn't see anything bout s/c spacer
throttle body spacer???
Unless your planning on using it to run meth. If your just thinking of buying it to keep the supercharger cooler then its a waste of money IMO.
you want to spray meth before the blower anyways to cool the intake charge for the boosted air IMO.
I think running it post blower makes more sense but I dont think the op wants the spacer for this reason anyways.
I have a snow performance meth kit but havent installed it yetUnless your planning on using it to run meth. If your just thinking of buying it to keep the supercharger cooler then its a waste of money IMO.
depends on what you want really. The spacer will serve two purposes in your case, a place for the meth to tap into, and to isolate the heat from the engine to your blower.
Whatever you do, dont buy zzp's overpriced crap. I sell a better product for less... you can check it out here.
http://www.grandprixforums.net/f49/phenolic-blower-spacer-17421.html
