Didn't know the modded 1.9's had modded pedestals too...I thought you retained the stock use and stock springs because they are modded stockers...maybe I'm wrong.
You need to modify the peds. Otherwise you'll see misfires on all cylinders as they don't open the valves properly.
If you use a caliper and measuer 10mm from the bolt opening, you'll have the correct clearnance. I've measured ZZP Peds at 10-13mm
I just bought a set of zzp modded 1.9 rockers second hand for real cheap. But, i just noticed they do not come with the modified pedestals. Am i completely screwed or what do i do?
Lol, you can tell the difference though.
Do you not read any posts after a rocker swap? Big notice after 4K or so. End of story.
