Just a FYI...you can get those reusable rocker bolts at a local hardware store
I found that out when I was pressed to get mine done after the cam build and they are like $.80 a pop...vs. the 20-30 bucks that they are from Comp Cams![]()
The ratio is determined by how close the pushrod seat is to the pivot point.
so in essence, a longer pushrod would make for a higher/longer ratio???
