T
TDCRacing
Guest
Roller rocker. Nuff said. Yella Terras. Nuff said.
You will bennefit in many many ways.
well I want stock ratio because I plan to cam.... however yes... the custom valve covers is what did it in. I don't understand what is up with these yella terras? for another car?
I just dont understand why we have to drill and tap the stock ratio ones but not the higher ratio???
I think you have to drill and tap your heads for the rocker arm bolts that fit that set. But I could be reading it wrong.
I've been running Intense Modded 1.9:1 Rockers since 2003 or 4. They've been great! These are the same thing as ZZPs, IWins, etc.
BTW, I strongly suggest upgrading springs when doing rockers. After putting 60,000 miles on my car with 1.9 rockers I had a stock spring break. Luckily I cought it before anything happened, then and there I upgraded to CC 105# Springs/Retainers. I could of easily dropped a valve and lost my motor. I somehow I got lucky. Keep in mind, I NEVER revved over 6K. Do some research on ClubGP, i'm not the only one I had this happen too, there are many more like me, although most didn't get as lucky.
The moral, when doing any kind of 1.9 rockers being stock modified or rollars, don't be a cheap ass, upgrade the springs/retainers and save yourself some trouble later on down the road...
did you have to drll and tap them like the ones on intenses website?
its decided. Im ordering these
Do you think its possible i can run a 3.6" or 3.5" pulley with these, the genV, and the N*?
I'm barely thinking I'm going to squeeze out good timing on a 3.8". I've got a ported blower, LIM, TB, 1.9s, 42.5# injectors, Plog, DP, and Wizaired. That higher CR affects things a lot.
