ls1camino
So, I'm building a L36 engine out of the car, so I can just swap the motor/trans at one time and not have my car down for an extended period of time.
I was originally doing a VS cam, 90# springs, stock replacement timing chain, and a 75-shot of nitrous. I was scared of going bigger (XP and 105#'s) because I DD this car, and I don't need a snapped timing chain.
I then did some research into the double roller timing chain and found that the failures were due to the camfer of the crank gear not matching the crank (Aussie vs US). Since it seems like an easy fix to get the double roller working properly, I'll be going with that. That got me thinking...since I now have a bullet proof timing chain, why not go XP with 130#'s and spin her to 6500-7000rpms and spray the 75 shot?
I then got to thinking that it would be easier to just put an XPZ cam and 130#'s in the car and not have to mess with wiring the nitrous kit or having to fill the bottle. It'll also free up the kit, so I can install it on my Trans Am.
What are your thoughts?
I already have a Gen V, full size intercooler, 42# injectors, mildly ported heads with valve guides machined down for a .600" lift (is that enough clearance for an XPZ?), and I'll be ordering a built trans.
I only have the stock L36 apart. I was originally going to just reassemble it with new rings and bearings. Do you think the rods will hold, or should I find some L26 powdered rods?
