    TIPS:
WTB stock headlight assemblies
I had TYCs in my '99 before I switched to halos, and I thought the quality was kinda crappy - maybe they've improved, those were a fair number of years old.
I have a super clean and clear aftermarket set that look just like factory. $60 shipped for the pair. Including turn signal lenses also. For some reason I cannot post pics here, but if you send your e-mail I can send pics.
Aftermarket headlights do not compare to factory GM headlamps in light output.
Aftermarket headlamp brackets that come with the aftermarket headlamp housings use an inferior quality plastic which translates to headlight beam bouncing.
If you can get a decent set of factory headlamps that the reflector is in good shape you may be able to restore the lens with a good lens restoration kit and a couple coats of high temp UV resistant clear, and use a good high temp clear urethane to reseal the lens to the housing as the lenses were sealed to the housing with poor quality urethane 13-20 years ago.
