Bedwards
I watched your videos, and I have never seen a supercharger belt also go around the alt., usually the supercharger belt is stand alone, maybe it has somthing to do with the pulley?
Anyway, from watching your vidoes I can say it sounds like its running on 5 cylinders, and judging by the "kickback" when cranking the engine, there is a good possibility the firing order is not correct, point being, there is an ignition anomoly, timing, fireing order, bad plug, burt/broken wire... or somthing.
I run the SS M90 kit. That's why the belt is like that. Which video did you watch? I fixed the no start/cranking problem.
