GOTIT4CHEAP16
yea sounds like a weak battery. How old is it?
Take a picture of your spark plug wires please.
Did you take a picture of the timing set when you put it on?
Run the ground wire for the icm right to battery neg and see if it starts then.
Did you swap injectors?
Get the balancer on straight?
Mine has pushed on and was off of the crank key, making the timing way off and it would never run.
Can you spin the engine by using the crank bolt?
