did u gave that battery a good charge yet?...or is the motor that hard to turn over that it creates resistance when starting?..like the guys stated before, the battery sounds weak (via ur videos), but i'm wondering if the battery is good and the engine is binding a bit.
from the earlier posts it seems that its not turning over by hand to easily either, that would be where id be concentrating on for now, the harness seem to be in the wrong direction to me.
maybe pull the plug wires and try to crank it, see it cranks any easier. still seems to be timing related to me, but we're not there to play with it.
What's the line that I circled?
Also it almost sounds like it's firing but at the wrong times. Is it possible you've hooked the injectors up incorrectly to the wrong connector? Looks like you've rearranged the wiring harness so that's a possibility.
Scotty, how would pulling the plug wires help it turn over easier?...u mean pull the plugs, then turn over?
I could be wrong in my thinking so someone correct me if I'm wrong.
Higher load springs could make it tougher.
The cam profile as well, since it's changing when valves open so more pressure may be building?
Almost sounds like the battery itself could be dieing. Ok voltage but low amperage. I hate trying to diagnose over the internet. Sucks ur all the way in canada. I'd drive an hour or two, but thats too far lol.
you are using the stock rocker arms right?
id pop a valve cove off and see what the valves are doing
any chance you could have the rockers to tight, that would hold it back for sure, maybe back off the rocker bolts and see if it tuns easier by hand," don't start it like that" it will bend a push rod or something for sure.
and come to think of it, did you lube the crap out of everything when you installed cam and lifters? soak the lifters in oil over night? and crank it with the plugs out to build oil pressure?
just asking, don't want to piss you off with obvious questions. i'd have maybe 3 or 4 hairs left if i were you right now....
Im a little drunk right now but is the supercharger and alt on the same belt? could that have anything to do with it lol
^Grease?:th_nervous:
You said the plugs have fuel on them, it might be they are fuel fowled, and there is no way in hell your going to get a spark off fuel fowled plugs. Might be in your best interest to replace them with some new ones.
Turning the engine over by hand is hard with the plugs in it, plugs removed, easy cause the compression has somewhere to escape. Turning the engine over by hand with the plugs in it, you will feel some binding...this is the pressure building up, you can turn it some more, and it will go easy on you for a little bit, then get hard again, this is normal.
One other thing you can do if you don't have a compression tester, is to remove the #1 plug, and hold your finger over the hole, and crank the engine over. If you can hold your finger on there, its probably in time, if you cant, then you for sure don't have it in time.
~F~
^^^^what he said,
when you cranked it with no plugs does it spin freely and fast like you would think it should?
